Hello,
Does anyone have any suggestions about where I might find some plans for a nice hope chest? I would like to make it out of cherry and line it with cedar. So far Norm’s Blanket Chest plan #104 is the winner in my book.
BTW I am relativley new to woodworking and I only have a few projects under my belt. I have built quite a few jigs for my shop, but I don’t want to try anything too complicated yet.
Wendel
I made one from "2x4 Furniture" book I picket up @ Lowe's. I've not done a lot of stuff and have limited amount of tools. This came out pretty good for a toy box.
Tom
I just built one for my wife out of plans in Wood Magazine (http://woodstore.woodmall.com/heirhopches.html).
I only used 2 panels in the front instead of 4 (see picS - FYI - 100K each), and made a few other minor mods, but in general everyone loves the design of the chest - add a nice cedar bottom and you're all set! btw - I made mine from White Oak.
Good luck - I'm sure she'll love it!!!!
d-
that Wood magazine blanket chest is a good one. It's all frame-and-panel construction, so it's not a technically challenging project, however it's also not just an afternoon thing.
the panels on this project are made by sandwiching together 2 pieces of 1/4" plywood. You could substitute aromatic cedar as the inside panel and make the bottom out of cedar.
Good observation - you are correct about the panels as indicated in the article.
For my part, I didn't like the flat panel look, so I did solid raised panels on the tablesaw. As I think I also mentioned, I did a T&G aromatic cedar bottom instead of the proscribed playwood.
For anyone else who decides to do TS raised panels, I HIGHLY recommend getting a Flat Tooth Grind rip blade (I used a 24 tooth Delta Rip Blade). Because you are moving at an angle to the blade, anything else (like a standard Alternate tooth Bevel, etc), despite having more teeth, will leave lines/grooves that are _very_ difficult to sand out. The FTG leaves very faint lines as well, but they are easy to sand...
Doug
Very nice! I think I have a new winner. Thanks for your reply.
-Wendel
Looks great. Did you make the bed in the background?
No, we actually purchased the bedroom set since I couldn't commit to any sort of reasonable timeframe to get it done (this whole "real job" thing slows me down!) :)
Believe me, I was quite pleased with how close a match the coloring was (the bedroom set is Ash).
Doug
Checking my Woodworkers Guide CD says check Woodsmith #58, American Woodworker #78 and Popular Woodworking 28,80,83
I am unaware of a CD that indexes articles from a multitude of mags. Details? Thanks.
Bert
Go to http://www.woodworkersindexing.com
Thanks! Looks like a great resource.
Bert
There are plans for a beautiful maple and cherry hope chest lined with cedar at:
http://www.americanwoodworker.com/200002/project_of_the_month.html
Cheers,
Matt-
Hello all.
I just wanted to let everyone see the (almost) finished chest. I still have to go over the finish a few times and add the lift. For those wondering, the darker wood is cherry and the inside panels are birch ply. The finish is tung oil. The Inside is lined with aromatic ceder ply.
So here are the pictures.
Thanks again,
Wendel
Wendel
Looks great. I didn't know you could get such a warm gloss with tung oil. This is the plan from Wood Magazine, right? I was looking at making one too, but wondering if you did something different to the top edge than the plan. I didn't notice the mitered corners in the plans.
Stan
Yes tung oil is great. It is very forgiving if you make a mistake and you can get a great warm finish from it. BTW I used Minwax's tung oil on this project. I did notice that it has a glossier finish than the Home Depot Bear version I have used in the past.
I did make a few changes from the plan by Wood Magazine.
1) I cut a tapper on the bottom legs instead of the curved cut suggested in the plan. The tapper cut matches my furniture better, but it does show the dado fillers more than the curved cut would. (If I had a better router I would have used a router to cut the dados and stopped before the end so that I wouldn't need the fillers.)
2) I changed the dimensions of the top and put a bevel on the underside of the top instead of a cove. The bevel matches my existing furniture. I cut this with my table saw, but I had to come back with a belt sander to finish it off. (The bevel was very difficult even with my fence extension. You really need an outfeed table and the fence extension needs to extend out on to the outfeed table.)
3) I put a triple bead on the braces for the top.
That's it. Everything else matches the plan.
Oh, one other thing. I finished the birch panels before I installed them. My thinking was that if I waited till after I installed them I wouldn't be able to sand and finish them as well.
