Hello…I recently bought a 1938 Philco console radio in a garage sale. The cabinet is very solid as is the veneer, however the finish is coming off in a few places, perhaps light water damage? I dont believe the finish can be repaired. What is the best way to remove all the finish so a new finish can be applied? What is most likely finish used in 1938? Thanks in advance.
Art
If you rub on some denatured alcohol and the finish becomes sticky, it's shellac; use lacquer thinner to test for lacquer. Can you post pictures?
-Jazzdogg-
I would be almost positive that the finish is shellac and as such, can be re-amalgamated by using more shellac.
If 1930 sure it is shellac.. I'll bet a dollar on it and I'm bloke!
EDIT:: Now where to find them old TUBES!
Edited 6/21/2005 2:30 pm ET by Will George
Will - Gretchen - Jazzdog...alcohol wont touch it, so I guess its laquer. Now - how do I get the old stuff off?? Sanding - what grit? scraping, or what???
Was the alcohol you used denatured alcohol, and not rubbing (isopropyl) alcohol?
Have you tried lacquer thinner to see what effect it has on the finish yet?
-Jazzdogg-
Edited 6/22/2005 8:38 pm ET by jazzdogg
Speakin of which:I have an old radio also. AM, FM, and shortwave in a neat art deco case.So, where would I go to get those old tubes?Thanks
Telemiketoo...chances are, its need more than just tubes. Filter capacitors dry out and/or leak. For tubes, do a search on google for tubes and there will be many to choose from.
Art
Art,
Try to amalgamate the finish with a 50/50 mix of denatured alcohol and lacquer thinner. Use a lint free rag and apply in circular motions first then with the grain.
You will have one of three things happen;
-Nothing
-Finish will fizz and bubble and most likely you will need to strip
-Finish will soften and begin to spread out evenly over the area in need of repair
If you find the finish is beginning to soften try not to be too vigorous with the rubbing. After a few minutes let it set up and you should have a dull patch with a thinned version of the original finish. Let this set up for a day or so. Then try to rub out with 0000 steel wool and wax to bring back the polish.
If that technique works, great. If not you may need to add a little more finish in order to have a sufficient film to rub out.
J.P.
J.P. thanx for the tips. I will try them this weekend.
art
