have to push stock through planer
I bought myself a delta portable planer for Christmas and I was using it for the first time tonday. We are fortunate enough to have 60 degree weather in the northeast for the first day of 2005.
I was planing some old bed frame parts (pine with a smooth finish on both sides) and I was having to push the stock through and in some cases pull from the back side. Was it the smooth finish on the pieces causing the rollers not to grab? If I had roughed them up with a belt sander would it have worked better?
This is the first time I have used a planer so please give me some advice. I saw another post on here about cleaning the bed and the rollers, so I just did that with denatured alcohol. Thanks.
How wide were the boards and how much were you trying to plane off with a pass?
Based on my own learning experience with a planer, you may have been trying to do too much with one pass. Give this a try:
Generally speaking, wider boards mean that you have to take shallower cuts. Harder woods like oak, birch, or maple also require shallower cuts. It's just a matter of practicing until you develop a "feel" for how to plane your stock. I usually prefer several shallow passes rather than one "hogging" pass. I also try to make my last pass just "kiss" the board - it gives me a better finish.
While I'm at it, be really careful planing "used" boards. Make absolutely sure that there's NO metal in them (even staples) or you'll soon find yourself practicing sharpening (or replacing) the cutter blades. If you're going to do this, invest in a good metal detector as soon as you can.
Been There, Done That, Got the Tee-Shirt - lol
Edited 1/1/2005 4:57 pm ET by Dave
The most finished wood won't slide nearly as easy as unfinished, so friction with the table surface is probably making feeding difficult. Placing the stock on top of a piece of plywood before feeding it through the planer would solve that problem. It never hurts to wax the table with furniture polish or a wad of wax paper to further reduce the friction.
A bigger problem is the possibility that you have trashed the blades by running finished wood through the planer. Many finishes are a lot harder than high speed steel so there is a good chance that the feeding problem is due, at least in part, to very dull blades.
John W.
Lower the blade no more than one-eighth to one-quarter turn with each pass. Also, wax the bed regularly. Waxing the bed should be a routine task. A wad of wax paper, as JohnW suggested, or paste wax, like MinWax or similar, will allow the material to glide smoothly through the planer.
You'll know when the blades are getting dull. It will be incredibly loud, especially with wide pieces, as the material passes under the blades.
tony b.
I have this problem with my planer from time to time, and it is from two causes. One is the friction with the table and as noted wax will solve that one. The other is the feed rollers may be dirty. On my little Delta the rollers get glazed over from pitch, which can be cleaned up with mineral spirits.
Rob Millard
Another good way to tell if the blades are getting dull is the shaving it produces. My planer with fresh blades it, spits outl shavings that kinda sorta look like Durkee fries.
This also holds true for other machine driven cutters. If they are churning out dust, it's time to trash 'em or send them out for sharpening.
