Is there a way to store Poly Glue? Other than the Bottle it comes in.
I do not use it to often but when I do the bottle cap is wasted around the third time I go to use the glue?
I have keep the air squeezed out between usage and still not much luck on Storage.
Many Thanks
Jimmy
As I recall, Gorilla Glue has a relatively short shelf life. I thinks I remember it's about six months.
The answer is to only buy what you need.
It helps some to store it upside down after squeezing the air out. I usually put the bottle in an old jar or some such. That way the skin forms at the bottom of the bottle.
I also, always but the smallest size bottle I can get by with for I have found that I loose any economy from the larger sizes to waste.
JW
