General International Accessories?
I bought a general international 14″ drill press a few months ago at my local Woodcraft. At the same time, I ordered the mortise attachment. They quoted 2 weeks for delivery, it’s now been 8 1/2 weeks.
I’m about to call them and nag (again) – do you folks know what my other alternatives are for sourcing that attachment? Is there a good online source for GI and GI accessories? Or another shop in MA that might be able to help?
Matt
I recommend you cancel the order. Mortising attachments on a drill press are not worth a tinker's da... I bought one for use on a Delta and it now sits on the shelf. If you were north of the 49th. I would send it to you for use as a paper weight. I always make a jig and use a template guide on my plunge router - - With a few practice jigs, you can get a perfect mortise. I just made eight mortises - 2 on each leg - for a kitchen table. F.W. issue 90, page 47 is one example and they had another article that got me started but I can't locate it. FW # 139-pg 80 is a good article on template collars. FW had another
I second Willy's suggestion you cancel the order. Whatever that accessory costs, put it in a piggy bank and keep adding spare change until you can get a mortiser. (You'll probably have enough saved by the time the attachment would be delivered the way "two weeks" has stretced!) Even an inexpensive tabletop unit will do a much better than the attachment. And, you'll save the endless hassle of switching back and forth between a drill press, mortiser, drill press, mortiser . . . .
Mike Hennessy
Pittsburgh, PA
Edited 4/27/2007 7:16 am ET by MikeHennessy
ok, ok! you guys have convinced me... I was initially thinking "heck, it's only $70 for the attachment, might as well get it and give it a shot."
Scoured Craigslist and found a Jet tabletop version for $125 - much better deal than the PITA that you guys say the drill press version is.
as always, thanks for steering me in the right direction.
Matt
