I use MDF as the top of my bench I build it, what will be a good finish that will protect it and give it a glossy resistant for spot so if I spill some water it will roll off and also protect it against spots.
Thank you
Moataz
Edited 8/5/2008 1:24 am ET by msw
I also made my work bench out of mdf and tried lots of things but what worked best for me was wipe on poly.
If its hot enough you can apply 2 to 3 coats a day.
Just a word of advise, don't build up so many coats that the table becomes slick, you just want to keep the glue and spilled water from sticking or being absorbed to the mdf.
Chaim
