I’m helping a friend who built his kitchen cabinets in cherry. Cherry ply for cases and solid for face frames. I’m building the doors and drawers out of cherry. He didn’t know cherry darkens with age. I showed him a sample and he likes the aged color. What kind of finish do you recommend? About how long will it take for the wood to get darker?
Fine Woodworking Recommended Products
Foam Brushes
Foam brushes are great for applying a variety of stains and finishes, and the 2" wide brush is the most versatile. Comes in a pack of 48.
SketchUp for Furniture Design
Craftsman CMEW213 Belt Sander
Weight: 6.6 lb. Amps: 7 Variable speed: No Belt alignment: Poor Material removal rate: Poor Sanding flatness: Poor Shaping/scribing: Poor Handling on side: Excellent Dust collection with hose: N/A
Rockler Complete Dovetail Jig
Spacing: Fixed Stock width (max.): 11 in. Stock thickness: 1/2 in. to 3/4 in. for through-dovetails (pins board can be up to 1-1/8 in. thick); 1/2 in. to 3/4 in. for half-blinds Half-blind depth: 5/16 in.
Osmo Polyx-Oil
"If I had to choose one of these hard-wax oils to keep on hand, it would be Osmo Polyx-Oil. It’s relatively affordable and very easy to apply." -Adam Godet
Mikeprinter
I'm sorry I missed your question.
Concerning the cabinets;
Cherry will deepen depending on how much light it is exposed to. It is a gradual process.
The optimum choice for a kitchen cabinet is a sprayed lacquer. If you don't have the capacity to do it, you can check local finishing shops to get some prices.
If you are going to do it yourself, a good varnish like Behlen rockhard would fit the bill.
If you are planning on doing the finish yourself, take some time to plan a schedule for application and drying times. Then you can balance out what your time is worth vs. paying to have it done.
Peter
Check this out
Cherry is one of the strongest wood, to know in detail about cherry kitchen cabinets visit this link.
