Reading the thread regarding the runout on the Delta drill press causes me to ask others about their experience with the 12″ bench drill press. I bought a 10″ Harbor Freight drill press about 2 years ago and the spindle actually moves causing the runout but since I got it for $40 I said okay, what did you expect? I was thinking about the Delta which sells for about $225 but if this runout is a problem then why get it. It seems to me the whole reason for having a drill press is the accuracy and if that isn’t there , there is no value at all in it.
What is the experience with the Delta bench press, is it good or are there other brands that I should consider? I am really surprised at these comments on the runout on that machine as it appears very solid; thanks for the warning.
I have a 16" Delta drill press, I believe it may be the model you are interested in. Have not checked runout, but have no problems withit. I bought it two years ago for about $225.00. Does not have quill stop or threaded fine adjustment. I am sorry I didn't buy the more exspensive one that has this feature.Overall it is a pretty good tool.
Thanks for your comments. Actually, I am looking at the 12" bench model which sells for about $220. I haven't found anyone that makes a bench model other than Delta. In fact for any drill press, bench or floor model, I have only found Delta and Jet offerings. Sounds as if there are also some accuracy problems with the squareness of the spindle to the table. I don't know whether going to a bigger (16" floor) model gets me any better accuracy but I doubt it.
As I said before, I would like to get an accurate machine because that is what I get a drill press for; my 10" HF has a runout that is intolerable and I don't want to be out another $220 or more and end up with the same problem.
Thanks again for all your comments.
I've got the 12" Delta Variable Speed benchtop DP. Just under $200. I installed the chuck correctly and according to the instructions. No runout that I can see - course I haven't mic'd it. Fine machine.
I have a Delta 16 inch drill press which I bought new about 5 years ago. According to my dial indicator it's the most accurate tool I own. The dial indicator doesn't move when checking spindle runout - something I've never seen before.
I have a Delta 12” drill press, and I like the machine. I hated the chuck that came with so I bought a super duty Jacobs ball bearing one. On the machine that I have, the stroke is not at right angles to the table as checked from front to back, which I found a little bothersome, but it isn’t the end of the world. I drill a lot of pins for card table and Pembroke table fly apron hinges, and these require a fairly high standard of accuracy, and the Delta works just fine. I have not checked the runout, but I think it would be minimal, by woodworking standards. I don’t see the need to have a super accurate machine that holds tolerances in the thousands of an inch, when I couldn’t and wouldn’t need to keep that level of accuracy.
Rob Millard
I have a 12" delta it does all I need it to do. No problems.
Darkworks: No Guns No Butter squilla and the bling bling.
Just what does this mean?
I have a Delta benchtop with noticeable runout...particularly when mortising.
That said, I suspect I could reinstall the chuck and get better performance...I think that the chuck is just off center.
Otherwise, it's a decent machine.
Has anyone ever taken off the chuck? How do you do that without damaging it?
Larry
Edited 8/2/2003 6:11:10 PM ET by Pat S
