Dado blade set and Vintage Craftsman TS
I am wondering if anyone out there owns a vintage Craftsman 10″ left tilting arbor table saw and uses a dado set with it. I recently found a vendor (McFeeleys) that actually sells an insert for the vintage Craftsman table saw so I purchased two of them. One that I will be able to use for a zero clearance insert and the other hopefully for a dado blade insert. My Craftsman table saw model is 113.29992 and I got it from my father who probably bought it in the 60s or maybe early 70s.
I just want to make sure I won’t run into any issues when using a dado set with this saw. Also, I would like to get recommendations on what dado set to purchase. Any help would really be appreciated.
Buzzsaw
“Don’t ask yourself what the world needs. Ask yourself what makes you come alive, and go do that, because what the world needs is people who have come alive.” Gil Bailie
Here is a link to the manual in case you don't have it.
Thanks for that. Now I have an electronic version. Can you recommend a dado blade set. Would it make sense to just buy a Craftsman set?Regards,
Buzzsaw
There is nothing unique about the Craftsman set that would make it work better in your saw than a set from any other manufacturer.
John W.
Thanks John but could you recommend a dado set that you are happy with?
Buzzsaw
I have the same saw and have been using it since 1975. My father in law had it before me and built a house with it. I have abused it to the max and it just keeps on a running. I started with an Montgomery Ward stacked dado set, have a couple of craftsmen dado sets, and my favorite is a CMT stacked dado set. Have also used craftsmen molding head cutter set.
My TS is a mid-80's vintage Craftsman and I use either a stacked dado cutter, or one of my two Craftsman wobble dado cutters. I seldom use it, but I also have a Craftsman molding cutter.
About five years ago, I tore the saw down to it's component parts and reassembled it getting everything dialed in as perfectly as possible. I added the Craftsman XR2424 fence and changed over to a linked drive belt and machined pulleys. The improvment was amazing! It runs as smooth as silk. Every time I think I would like to upgrade to something better, I wonder if I would get enough improvement to justify the cost.
I make my own zero clearance inserts from 1/4" plywood. I trace around the stock metal insert and cut several inserts on the bandsaw, sand them to fit the insert opening, and drill a finger hole in each one. I use 3-4 strips of duct tape on the bottoms to bring the insert up to table height.
I have inserts for my 10" blades, an 18mm dado stack, and a 12mm dado stack. For one job, I made an insert with the slot at 45* so I could get clean miter cuts on 1/2" walnut plywood. I keep 2-3 "blanks" handy in case I need to make up a special use insert.
I finally got the $ together to buy the Forrest 8" stacked dado set, and really enjoy it!
Excellent cutting with flat dado bottoms, accurately machined blades and chippers.
Pete
Here is something to check. There is a problem with the arbor on most Craftsman Contractor Saws that affects the quality of the cut when using a stack dado. I don't know if it also appears on their Table or Cabinet saws.
The arbor on Craftsman contractor saws has a deep groove between the threaded portion and the flat unthreaded portion of the arbor. Any chipper that would end up resting in this area will not cut in a concentric path and the bottom of a dado will not be uniformly flat. There is a DIY fix for this. However, the threaded portion of the arbor is slightly smaller in diameter than the flat portion so any chippers or end blade will again not cut in concentric paths. But, the error is small and most ignore it.
Thanks very much for the info from all of you. I purchased a Vega fence a couple of years ago for my Vintage Craftsman TS. It made a tremendous difference. I am looking forward to purchasing my first stacked dado set.Regards,
Buzzsaw
