I tried to cut plastic crown molding on the table saw, and it gets messy. The plastic melts. I don’t have a miter saw, but expect the result would be the same.
How do people cut plastic crown molding?
I've never cut plastic crown, but I cut Azek (PVC trim boards) a lot, and have never had any trouble using a high-tooth count carbide blade in a TS or miter saw.
Mike Hennessy
Pittsburgh, PA
gj13,
I haven't cut crown molding, but I cut a houseful of plastic baseboard a few years ago. The first cut on the chop saw melted the plastic. I have never completely gotten all the plastic off that blade. The only way I could get the job done was to cut as fast as possible, bringing the saw down and back up as fast as I could to prevent heating the material.
Rich
Steel plywood blade installed backwards works in a mitre saw
Try a high tooth count carbide blade installed backwards.
I did this with vinyl siding on a SCMS, and it eliminated a pesky blowout at the fence.
kreuzie
Having never worked with this material I have no idea whether or not you have already gotten a useable answer to your question. Breaktime would be a good place to make such an enquiry.
Yeah, I thought about posting to Breaktime. Knots is where I tend to browse, though.Thanks for the answers, guys. Looks like I'll try it with a backwards blade next time.
fiy that also works for aluminum soffit and flashings. not that it helps you in this situation but it may eventually.
