I have a table top made of curly maple, legs are walnut. I have some tear out and want to repair it. I am going to finish the top with Tung Oil and Lacquer. I have tried the hide glue and saw dust trick and I am not satisfied with the look- the color is off and I don’t want to dye stain the top. Any ideas/trick you guys use?
I was cautious taking 1/32 off with the jointer and a little on the planer.
thanks Dave
Sometimes you just have to reach for the scraper or sander.
I'd say you almost always have to 'reach for the scraper or sander'
Have you tried clear grain filler?
no, i might just have to try that one, keep the suggestions coming? thanks
Works good. You want to do your dying first. Then fill. Goes on in a milky haze but dries clear in an hour or so, then you can sand it back. I've had several brands but my guess is several of them are made by the same manufacturer. Usually comes in tubs about a quart in size. Any questions, ping me.
Denny
A first-class handplane, sharpened to perfection, and set to a super-thin shaving.
I recommend Lie-Nielsen's DVDs with David Charlesworth.
Good luck,
Geir
Geir,
I'd like to add that while sharpness is important, the proper bevel angle is even more so. For curly maple, I'd suggest a +50 degree effective cutting angle.Chris @ http://www.flairwoodwork.spaces.live.com
Yes, you are absolutely right about the cutting angle.
I have handplaned some very curly maple for violin backs and ribs ("sides") and a higher angle eliminates tear out.
Geir
I've been using gap-filling super-glue and accelerator spray to set it. It fills small tearout nicely, sands or scrapes smooth, and disappears completely under shellac or varnish.
Not my original idea, but it sure works for me.
Mike D
"I've been using gap-filling super-glue...." Mike, a little more detail maybe? I'm assuming this is different from the ubiquitous super-glue found at Safeway or Ace. Is it a fairly common item, or harder to find? I'd love to have this bullet in my armory.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Many woodworking supplies carry it. The cyanoacrylate I'm familiar with comes in three viscosities: Hot Stuff=watery; Super T=syrupy; Special T=thin molases Chris @ http://www.flairwoodwork.spaces.live.com
Which one fills gaps -- I've neve thought of CA glue as being at all gap-filling. Sorry if I'm being dense.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
In this case, gap filling means good for small gaps such as between pen tubes and blanks, not grand canyons like polyurethane glue. The thin stuff is more suitable for putting broken ceramic back together. Dense? Lignum Vitae is dense!Chris @ http://www.flairwoodwork.spaces.live.com
Hi Forest Girl,
I use Super T found here http://www.woodcraft.com/family.aspx?FamilyID=346 at WoodCraft. It says that it's slow curing, and indeed it is, so I also use the accelerator spray to harden it up.
It works fine for small tear out in curly maple from the jointer or a handplane that is starting to get not quite as sharp as it should be.
Best regards,
Mike D
Thanks, Mike. I've been using epoxy for such little tiny imperfections, but it's such a pain to mix a blob when you only need a tiny bit.
Reading the descriptions, seems like either the Special-T or the Super-T would work? Question re: the accelerator....it's a spray application, and the notes say it "doesn't evaporate." Do you mask off the surrounding area somehow, or is that not necessary?forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Hi Forest Girl,
I use the Special-T. I don't worry about the accelerator not evaporating (although it seems to evaporate just fine), since I sand and scrape the area that I've put the blob on, anyway. It does make a blob, so it does require leveling off.
Mike D
thanks
Dave
Woodchuck.
If filling makes more seense to you than sanding or scraping or planeing and risking more tear-out, try a trick Jeff Jewitt wrote about. Use plaster-of-paris as a grain filler. Apply it as youi would grain filler, as it sets wipe it off across the grain with burlap or other coarse cloth, sand when dry. I'd use blo instead of tung oil. It dries faster. When it hits the plaster=of=paris, it turns translucent. Give it a few days to dry, then hit it with the laquer.
Plaster-of-paris is cheap, so try it on a piece of scrap and see what happens.
Steve
There are two secrets to keeping one's wife happy.
1. Let her think she's having her own way.
2. Let her have her own way. President Lyndon Baines Johnson
I've been using plaster as a filler for oak for a long time. Learned that from my grandfather. Sands smooth as silk and the little white flecs just disappear when the piece is stained.
Ray,
I used it once on yellowheart and once on purpleheart. It's easy to apply, dries fast, sands easily as you said, and it's transparent under a finish. Thought I was crazy for trying it until I tried it.
SteveThere are two secrets to keeping one's wife happy.
Most people I tell about plaster think I'm totally nuts - until they try it too :-)
I was pleasantly surprised by a recent purchase of a 5 1/2 Lie Nielsen hand plane. I am able to plane curly maple and even birdseye maple without tearout. I have with much tuning and fiddeling been able to do this also with a #5 Stanley also but not with the standard iron. The mouth must be very tight, iron very sharp and use long, slow and steady strokes. If using a stanley a replacement hock iron and chipbreaker would be a wise $65 upgrade. And once tuned up, only kept for such tasks. the rusults however are impressive and might make you toss your sandpaper. By the way I don't work for Lie Nielsen but would not refuse if offered ;-)
Walnut Pete, is that the No. 1 Bench Plane by Lie-Nielson?
That is, in my opinion, the best plane that can be purchase under $400. Of course Clifton and other 'gold plated' brands are much more expensive. I like the Lie Nielson 5 1/2 because that is ths smallest plane with a tote that does not cramp my hand. Smaller planes won't let all four fingers fit on the tote. Most well known and published hand tool craftsmen say that the larger the plane the flatter the surface. The Lie Nielson like the older Stanley Bed Rock planes allow the adjustment of the mouth with out removing the cap iron and loosen and adjust the frog. Then there is 15 to 20 minutes of adjusting to set the iron again. The machining is great also. You can almost see your reflection in the sole and the plane body sides are exactly square to the sole. I paid $345 for my 5 1/2 and fell in love the moment that I started the plane in the wood. I am able to take 1-cell thick shavings in birds-eye maple without tearout. I produces a surface that is smoother than a card scraper and certainly better than sandpaper.
great, someday soon I want to by a Lie Nielson or two, thanks for the info. check out the table in the gallery forum, thanks
DaveChildren are our future, unless we stop them now -- Homer Simpson
wood , you have a bunch of fix it suggestions here, so I will just say next time dampen the wood just before you joint and plain . most important NEVER EVER put laquer over tung oil!!!!!! I have two tickets infinishing and over25 years finishing behind my ,that is the biggest no no . good luck -Dan thewoodbug
Can you explain why tung oil over Lacquer is not advisable? thanks
the main reason to not put lacquer over tung oil is that tung oil was deigened for outdoor use there for it never complettelly dries (meaning it stays fexable allowing the wood to breath. If your goal is to pop the grain and inhance the natural wood coulor? you can use danish oil (Watco is good w/ lacquer) wipe your oil on leaving it on for only 10 min/or so then wipe dry , by the next morning your peice should look as if you never oiled it (thats ok).Wait 48-78 hours before lacquer sealer and then final lacquer top coats. Dan thewoodbug.
