I recently bought a Crown 8 inch dovetail saw. The blade seems to be coated with some sort of plastic coating. How should this be removed?
It would have been easier to answer if you had inserted pictures. You can consult the place from where you bought it.
problem solved
I was able to take off the coating which I assume was some sort of lacquer using acetone obtained at CVS as fingernail polish remover.
