Hello Folks,
I just purchased an old wooden tool chest. Classic, 4-board chest with 2-board lid and inside tray. Ship’s handles and big hinges, pine and nails. The bad news? It has been closed for some time and is mildewy inside, the lid has a big (motor or other) oil stain on it, there are some oil splotches inside together with the midewe and spider’s cocoons.
When I cleaned teak brightwork on boats in the seventies, I used Tip Top Teak Crystals (some sort of crystalline bleach mixture), water and a scrub brush to scrub and bleach the grayed-out teak. Once done I would oil it to a warm reddish-brown tone of luxury. Boat owners were always willing to pay those bills.
So I am tempted to do the same thing here, but worried about saturating the pine with water. All the pieces are there and relatively well-aligned, so I am not too worried about stuff veering off into space. I thought I would bleach the wood, let it dry, then use Tried and True Linseed oil. Do any of you see dangers I am too ignorant to see on my own?
Thank you,
Lawrie
Sunshine and fresh air (Dry)Fan/blower Also, an ozone generator can eat up all the odor.(Thry can be rented) If you confine the opened box and the generator in a small closet it will expedite the process. I,m thinking one of those free standing gadgets called air fresheners might do (As they work on the same principle) Stein.
Remove the green felt and replace with new felt you pre glued to paper board and then cut to fit.
The oil may be removed with some paint thinner applied, then scrubbed with pumice with a scotch brite pad. Clean, and
repeat as neccessary.ED.
Edited 5/9/2005 3:31 am ET by steinmetz
