Has anyone carved a swan neck molding or know of any sources to learn the
technique? Thanks to all.
I have... what would you like to know? I start by marking out the fillet at the top of the molding, then chop down to that level. I then roughly waste about a 45 degree angle down to the lower fillet (there is usually a bead there, too). I attached some photos that might explain a bit better... the photos are of a gooseneck for a highboy, but the process is the same. I never waste my time with routers and machines - too time consuming for too little advantage. Notice that in the photos the edge that is to be mitered doesn't get carved until the miters are done and put together - this ensures that they match.
Do finish the surface with contoured scrapers?
Yes... I make a lot of my own scrapers from saw blades.
Do you have a picture of the finished molding?
No, but if you go to http://www.taunton.com/finewoodworking/Gallery/GalleryImage.aspx?id=30910
this is the highboy it comes from.
There are a couple of ways you can do this combining power tools and handtools. Theres no way to do the whole job with the hand tools so there will be some carving involved.
I remove the concave portion of the neck with a pin router and an index pin to follow. You can also rig it on a router table.
I believe Lonnie Bird has a section on this subject in his book Shaping Wood.
You can carve the entire piece as another option. With softer woods its not too tough. With hard maple it might be worth thinking of the router.
Good Luck
The molding for a clock is so small, I can finish with hand tools before I could get the setup done for a router of any kind. Of course, my prejudice is showing - I hate routers with their horrible noise and dust flying everywhere.
Take a look at these 2 responses on knots.
32581.3
7114.6
good luck
dan
