I was considering a set of forstner bits at woodcraft on sale (Chinese HSS), and I was wondering if the bump in cost is worth moving up to carbide(and a brand name)? What brand do you have experience with? Do you buy the cheap ones and chuck them when done? Thanks in advance.
I have been happy with the steel forstner bits. I think the HSS bits from lee valley are a bit (pardon the pun) better than some of the other less costly bits. The lee valley bits have a hex shank for the larger size and are a bit longer.
Troy
Bones,
If you're going to be boring holes in manmade sheet goods or teak, the carbide-tipped Forstner bits might be worthwhile. Carbide is durable, brittle, and costly. You'll have to ask yourself whether you'll drill enough holes to make them pay for themselves.
Good luck,
-Jazzdogg-
I bought a cheap set in a nice carrying case. Plan to replace the most-used ones with higher quality when they wear out.
A long time ago, I ponied up the $$ for a complete set of the HSS bits from Lee Valley.
At the time, I thought it was an extravagance to get a set with so many different sizes, but I can't tell you how many times it has been handy to have an odd size.
I think the set was in the neighborhood of $250-300. The quality seems adequate -- at least I haven't sharpened any of them, and I still get nice, clean holes.
I have never tried any of the carbide Forstners, but I would think they are unnecssary -- unless you are using one for large production runs. The HSS bits seem to do fine in man made materials.
"I would never die for my beliefs because I might be wrong."
-- Bertrand Russell
my hinge cup boring bit is carbide because I use it a lot. I only have a few others and they are all steel.
Bought a set of cheap Forstner bits about three years ago. Plan on replacing the most used bits with higher quality ones from Lee Valley. So far I haven't replaced a single one but the 3/4 inch is coming due.
Mine are a mix between the old Craftsman HSS and the Austrian HSS that Woodcraft sells, plus one Bosch bit.
Worked well so far. The 3/8 Bosch bit had to be re-ground to get decent chip ejection, I was less than thrilled to discover it's shortcomings, but Jameson's (my sharpening folks) got it going properly.
