In the “Methods of Work” section a subcriber gives a tip for making a carbide scraper suitable for drawer corners (my application). BUT when I go to the site he mentions (Carbide Depot) they only seem to list the insert he uses in qty’s of 10, cost being $171 ! Anyone know of an alternative source?
I can't find the article but are they carbide inserts like user in machining?
http://www.grizzley.com/products/searchresults.aspx?q=carbide%20inserts
Or inserts for spiral cutter heads?
http://www.grizzly.com/products/14-x-14-x-2-mm-Inserts-Carbide-10-Pak/H7319
That's all I can imagine without the artical.
Scott
Thanks for response. Article is on page 16
I like a small Red Devil hand scraper with double steel blades. They are easy to sharpen and are much keener than carbide.
Lee Valley carries carbide blades as replacements.
Rounded blades: http://www.leevalley.com/wood/page.aspx?c=&p=44507&cat=1,190,43040,43041
Square & Rectangular blades: http://www.leevalley.com/wood/page.aspx?c=&p=20095&cat=1,190,43040,43041
Chris @ flairwoodworks
