I recently purchased a beautiful slab of 10/4 figured cherry. I plan on making it in to a small table top or bench seat. It has been air drying but still green. The slab is clear except for a check on one end that is about 6 inches long. I plan on using a butterfly key to keep it from getting worse. My question is, is there any harm in inlaying the key now to prevent the check from getting worse? I have only used butterfly inlays on already dried boards. I can’t think of a reason why I can’t do it now but wanted more advice before I did it. This board is too good to waste.
Happy Woodworking!
fordtruckguy ,
The first thing that comes to mind is exactly how wet or dry is the slab , you prolly want to glue the inlay in right ? If the moisture content is too high the glue may not work ?
Why not fit the inlays tight but dry , if they still fit then glue them in later.
regards dusty
Thanks for the reply oldustyThat is a very good idea. My moisture meter seems to have gone missing so I will have to wait a bit for an exact reading. I will dry fit them and worse comes to worse they don't fit in 6 months to a year and I will just cut a new inlay. Thanks again.
Your Welcome from a Ford Van Guy .
There are some devices designed for that purpose, one is a S shaped iron and one is shaped like a staple with the outside of the points straight and the inside on an angle, you drive both in the end grain.
The S is mostly for logs, the staple (about 2" wide with points 1" long) actually brings the lips of the split together.C.
FTG,
When timber dries and the forces that open a split increase, those butterfly thangs will put a stop to it. I often wonder: where does the split-force then go?
Does it stay locked up and somehow resolved in the timber, like the case-hardened plank that only jumps into two bananas when ripped? Perhaps it travels elsewhere (like the other end of the plank, where a new split opens) or does a jig and comes out sideways (as a twist or wind perhaps).
Still, its a well-known technique and seems to work. yet I still wonder where those splitting forces go.....?
