I have a cherry dresser (Thomas Moser copy) that has a black ring from a glass of water. The finish is BLO with paste wax topcoat. Can this ring be removed, if so, how. thanks
Brian
Brian
When a water ring is black (rather than white), the water has gotten below the finish and into the wood. None of the quick tricks will solve this problem. As far as I know, sanding (or possibly bleaching and restaining to match) is the only way to fix it.
It might make sense to strip and refinish the whole top with something a little more water resistant. Like Buckminster Fuller used to say, it's easier to re-engineer the built environment than to re-engineer human nature.
Before you try to sand out the black ring, try a strong mixture of Oxalic Acid and water. This is often a solution for black spots and rings. It may not work but it might minimize the amound of sanding you have to do.
Bill
Bill's suggestion of Oxalic acid it the correst one for black rings in wood. It's been my experience that if water will penetrate the finish to make the ring, oxalic acid will get through the finish to remove the ring.
Sherwin Williams sells oxalic acid as Wood Bleach. It comes in twelve ounce plastic tubs. Read the label; make sure it's oxalic acid only and not a two component bleach. That's a whole other subject.
Apply a hot saturated solution to the stain, let it work for a few minutes, and re-apply periodically until the stain disappears. It usually only takes a few minutes, but I've had it take up to an hour to get deep stains out.
As soon as the stain is gone, rinse thoroughly with clean water. Do not breathe or ingest the dry powder or the solution. If there is white opowder on the surface after drying, you did not rinse it enough, so rinse again.
You'll probably have to touch up the finish, but with linseed oil, that's easy.
Michael R.
thanks alot folks. I will try the oxalic acid. I used to get that stuff from a drugstore when I was a kid. We used it to remove rust from old beer cans.
Brian
WHY?
JohnW.
Silly other hobby I had (have) "Beer Can Collecting".
