All,
Yesterday I resawed 4 slabs of black walnut 4″x17″x5/8″ and today I need to cut 4 more 3/4″ thick. I just checked and two of yesterdays piecs have twist….the grain is straight and the wood was dry. How long should I wait before I try to reflatten the pieces? The piece of stock started out as about 4x4x37″ and after planing sat in the shop for about 3 months….
It sounds like this piece of stock from which you cut had been drying for only 3 months. If so, it wasn't dry by any means. If it came to your shop kiln dried already, it may have reached a fairly low moisture content but my experience in working with 12/4 or 16/4 stock is that you will get some movement after resawing. I typically leave it sit, stickered in my shop for a week or so after cutting and before milling to finished dimension.
Kell
Kell,
My sense is the piece of stock was kilm dried....the twist was in two of the pieces and not in the other two. So I'm thinking this is a reaction to internal stress? ..rather than moisture? ...and if it is stress related, how should I wait before re-leveling? is a week on stickers enough in this case?
Since thinner walnut is cheaper and readily available, why buy thick slabs and resaw it?
As for drying, air drying on gunstocks blanks is 5 years...
Michael,
I happened on this black walnut for free..and was going to save it for table legs or something like that. But, I saw an interesting chess board and figured it was just enough to build that too.
I wasn't trying to be a smart ####! Just wondered why, free wood being as good a reason as any!
Michael
I'm not sure what the right answer is but I think waiting a week with pieces that thin should be long enough.
As to why it twisted in the first place, it could be internal stresses. Were the two pieces that warped closer to the center of the piece than those that didn't? If so, I'm thinking it's more likely moisture change. If not, internal stress would be indicated. Perhaps Jon Arno could weigh in.
In any case, good luck!
Kell
Kell,
I'm fairly certain the two pieces that warped were from the outside of the stock (as opposed to the interior of the stock)...I'm positive at least one piece was. I resawed the two outer faces, re-planed flat one side and re-sawed again from that side. The twist appeared the next morning. It planed so beautifully.
The grain is straight but runs diagonally down the lenght...I think the twist followes the grain ...
I have another chunk to slab up (from the same piece) and it'll be a real pain if it twists. I need 4 pieces with a final thickness of 3/4"..and I have a 4" thick piece...so there is not a lot of room for twist. If there was somthing I could read in the grain, perhaps I could cheat on certain cuts and allow more wood movement on other pieces....
"the wood was dry"
Dry is a relative term. Since this walnut is for furniture, it should be in the 6-12 % moisture content range. The thinner you mill it, the more likely it is to warp. Try to keep the lumber in a stable environment and check it with a moisture meter.
