I recently read somewhere that when you router trim the access arborite off of a table top that it should bevel back a bit.
Is this true and if so, how much and with what router bit. thanks, bob
The usual laminate trimming bits in the US bevel the laminate at 22-25 degrees. Sometimes they're explicitly called formica trimming bits, and sometimes just bevel bits. Often they're packaged with a flush-trim bit. You use the flush bit on the strip at the front of the counter, and the bevel on the top piece as it overlaps the front strip. Get a bearing-piloted one.
thanks jamie-appreciated
I assume you're talking about plastic laminate (Arborite also makes solid surface material, similar to Corian).
The piloted bit the previous poster mention is a good way to go. But you can also get a slight bevel with any double cut file, followed by a couple of passes with sandpaper wrapped around a sanding block. This technique leaves a barely perceptible bevel, and it does remove the sharp edge.
You can buy a file designed specifically for laminate work from any place that sells laminate supplies, and most tool outlets.
Bob, When building tables and counter tops, I often edge the substrate with a hardwood strip, then the laminate on the edge, then the top. I then take a 45 bevel bit (with bearing) and cut a 3-6mm facet on the corners both horizontal and vertical.
Its a bit more work but leaves a nice wood reveal and helps stop the laminate corners from getting damaged.
