I am currently working on some plans for a contemporary coffee table (see attached PDF), and would like some advice on which kind of joint I should use. The plan currently calls for a veneered plywood of some sort to form the sides and top (Birch or Maple… I am open to suggestions here), however, I am unsure as to how I should go about joining them. My first thought was use a spline in the miter, but I am not sure that is the best option and also not too confident in my ability to cut the groove for the spline in a compound miter. My second thought was to just use a simple miter and reinforce the inside of the corner with glue blocks. Any suggestions?
Also, does anybody know of a good supplier of metal furniture legs and the like?
Thanks for the help.
Doug Mockett has your legs: http://www.mockett.com
Constructz,
Try biscuits and an accurate saw cut.
Using a glue block, installed during mock run for glue-up would help no end with alignment. That way, the screws will relocate in the holes when the glue's on the job and automatically locate things.
Just a thought - others may have other ways.
Cheers,
eddie
The major issue with the construction you are planning is matching and protection of the face plies at each corner. These plies are very thin and achieving a perfectly fitting compound mitre is challenging. Once you achieve the well fitted joint there may only be a few thou of the face veneer left to protect the corner. I would expect that this would not be durable. You may want to review the design to incorporate a solid timber edge (or corner post) along the compound mitre. This could be in the same or a contrasting species to your face veneer. If you adopt this treatment, you could cut a rebate in the corner post and just glue the ply sides to the post – masking take would probably be strong enough to act as a clamp whilst the glue sets.
hope this helps, Ian
I would run a rabbet on the outside ends before glue up then inlay a small strip of contrasting wood, Ebony, wenge etc. after assembly
Corner blocks for strength and biscuits or dowels for alignment.
Edited 6/4/2004 4:16 pm ET by Shopmole
I second ians comment for the long haul or even do it in solid wood and use dovetail splines for additional style points. You could also build it out of MDF with biscuits and glue blocks and then veneer it with thicker shop made veneer. Either way it a cool design so have fun making it.John O'Connell - JKO Handcrafted Woodworking
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
Thanks for the help guys, I haven't totally decided how I am going to approach this (and probably won't until the last minute) but ya'll have provided some great ideas. I especially like the idea of using a contrasting hardwood for the corners.
Thanks for the help!
