I’m having problems with a job making laminated beams. I glued up 5 pieces of ¼” teak on a 60” radius template in a vacuum press using titebond 3 glue for 5 hrs. They spring back changing the radius to about 62”.
I tried a test using 7 pcs. of 3/16” teak, and it still doesn’t hold the radius.
Has anyone had some experience with this problem?
Ron S
Hi Ron,
Sorry for the long delay in responding. Your question got lost in the digital shuffle.
Check out Michael Fortune’s recent Q&A piece on bent laminfor more info:
http://www.taunton.com/finewoodworking/subscription/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=30959
Springback is the most common problem with laminations. Sounds like your laminations are too thick.
For more information, check out our Web site section on bending wood:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesDirectory.aspx?dir=Bending+Wood
Good luck with your project,
Gina
FineWoodworking.com
