I am building an expanding dining table that has two 22 inch leaves. I want the leaves to have an apron that matches the apron on the rest of the table. For the main table the top will be attached using scrap blocks that have a tongue that fits into a groove in the apron. But what is the best way to attach the top to the apron for the leaves? It seems like a couple of these blocks will not be sufficient to hold the apron on yet gluing 22 inches cross grain seems like asking for trouble. Any suggestions? I have looked at several books but none seem to address this specific situation.
thanks
Jeff,
You're right to raise the question. Sometimes the grain direction in the top is switched to eliminate the problem. But if you do not want to do that, you're better off using screws through the apron, set in elongated holes to allow for movement. I usually close these screws down tight and then back off half a turn. You might want to beef up the thickness of the apron in spots just to make it sit more securely.
DR
Not that I feel this is a solution of a true craftsman, but it's not uncommon for table leaves to be missing the apron.
Just a thought...
Jeff,
What ring says. Three screws should do it. Center of the leaf, screwed fast, the ones near the edges, in slots to allow for movement. Try to avoid running the screws into a glue line.
You could use sliding dovetails. NO GLUE and a small brad or screw at center line to keep the apron from moving..
Just how I would do it.
